Unphysical peaks in the pressure field at sharp corners – why?
Old   March 5, 2016, 06:35
Default Unphysical peaks in the pressure field at sharp corners – why?
Josef Camilleri
jcamilleri is on a distinguished road
I am simulating the water impact of plate inclined at an angle of 10 degrees, in Star CCM+, see geometry and mesh in figure 1. Around the sharp edges of the plate, in a few prism layer cells, I am getting very high negative pressures, which are unphysical, see Figure 2.
At first I thought that this is occurring because at the corner I have two cells attached to two different boundaries (no-slip wall condition) and the common face gets information from these two cell centres, so it tried the mesh in Figure 3 (which is very bad mesh but I wanted to test this) however the problem still happens.
I also tried refining the mesh around the corners to limit the aspect ratio of the cells but it did not help.
I have read that sharp corners are points of singularity in CFD. But why? Is it the boundary conditions? Or because Star CCM+ uses the cell-centred Finite Volume method? I am more looking for a 'technical' answer to why this happens with the methods used in Star CCM+ in mind.
Thank you for your time.
Regards,
Josef
jcamilleri is offline   Reply With Quote
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
How to get the velocity field from the pressure field Hermano Main CFD Forum 2 November 29, 2011 09:32
Gas pressure question Dan Moskal Main CFD Forum 0 October 24, 2002 23:02
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) HB &DS CFX 0 January 9, 2000 14:19
