How to create matching mesh zones so that periodic boundary can be created in Fluent
Old   February 26, 2016, 14:39
Default How to create matching mesh zones so that periodic boundary can be created in Fluent
Carson
cgoodale1 is on a distinguished road
I am meshing a geometry in Star-CCM+, exporting the mesh to a Tecplot and importing the Tecplot into ANSYS Fluent. The issue I am having is that I need to create matching zones on the sides of my mesh so that when the mesh is imported into Fluent I can successfully create a periodic boundary between the two zones. If the zones do not match perfectly then the periodic boundary can not be created in Fluent.
So far I have tried creating a periodic interface in Star-CCM+ and remeshing but the zones still do not match when I do that. Is there any other way to mesh so the zones match each other?
cgoodale1 is offline   Reply With Quote
Old   February 26, 2016, 16:04
Matt
fluid23 is on a distinguished road
Why are you meshing in star-ccm and exporting to fluent? Why not run with star-ccm?
fluid23 is offline   Reply With Quote
Old   February 28, 2016, 11:52
Lucky
This happens fairly often actually. Because historically Fluent did not have it's own meshing utility, and the Star-CCM mesher has some neat things it can do as well. On the other hand, Fluent has more solver options (even though it has fewer meshing options). Finally, it's great for benchmarking Star-CCM vs Fluent results.
Does this mean that meshing failed? You need the periodic zones to match in Star-CCM before your export it to Fluent.
Are you using some options like per-region meshing which does not produce matched interfaces?
Also play with your meshing criteria to see if you can get a matched boundary.
Alternatively, you could do a non-conformal interface, but I do not recommend this approach at all.
Old   February 29, 2016, 13:34
Carson
The meshing did not fail but when I created an interface on the surfaces that I wanted to match there were still different numbers of elements on each face. I am not using per-region meshing. I mesh the one region as a whole. I have played with the criteria but have not had any luck yet. Could it be the approach that I am using when I create an interface between the two regions?
matching tolerance, matching zones, periodic boundary
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 10:38
[ICEM] how to create a 2d tri mesh with quad mesh in the boundary layer seal2013 ANSYS Meshing & Geometry 3 October 6, 2013 17:09
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
