Particle reached maximum residence time
Old   February 9, 2016, 12:38
Default Particle reached maximum residence time
Robin Cato
Catostrof is on a distinguished road
Hi everybody,
I am working on a separation cyclone with Lagrangian multi-phase.
I have problem with my Cyclone simulation.
I have simulated with particle size 1*10^-4, which I have to.
The problem is the particle circulates for a long time in the cyclone and reaches the maximum residence time (100 sec.) and the sub-steps are set to (1 000 000). I tried to set the residence time to 500 sec. but i get the same issue. I tried with a smaller particles ( 1*10^-5 ) and it works perfectly.
I have set boundary to Wall with Escape for the outlet in the bottom.
If anybody can help me to troubleshoot this issue I would appreciate it very much
Catostrof is offline   Reply With Quote
Old   February 12, 2016, 09:34
Nils
Deranda is on a distinguished road
here you got an extract from another guidline
When running steady state, the flow solver is not time stepping. In a single iteration, the Lagrangian solver is resolving the particle track from the particle entering to the particle exiting the domain. To generate a particle track, the Lagrangian solver has to substep with the particle trajectory and velocity to march out the path of the particle. In this way, Lagrangian substepping is analogous with time-stepping in unsteady models. The Lagrangian solver also knows from the particle velocity and track distance traversed how long the particle has been in residence, that is, the solution time that it has been in the domain. You can set a maximum residence time and/or a maximum number of substeps, after which it aborts the substepping and stop tracking the particle. In doing this, the solver does not continue to solve a track for a particle that never leaves the domain. Substepping occurs during a single steady state iteration. This is why it is only necessary to run the Lagrangian solver for a single iteration to generate the particle track - the Lagrangian substeps are internal to the solver iteration
Deranda is offline   Reply With Quote
cyclone separator, particle, residence time, sub-steps
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
simpleFoam error - "Floating point exception" mbcx4jc2 OpenFOAM Running, Solving & CFD 12 August 4, 2015 03:20
Particle residence time Raymond.Leoi FLUENT 0 July 22, 2014 06:54
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Check particle impaction with User Fortran Julian K. CFX 3 January 12, 2012 10:46
