Flow simulation moving in the reverse direction
Old   February 6, 2016, 20:26
Default Flow simulation moving in the reverse direction
Samuel Alfred
samoalfred is on a distinguished road
Hello everyone. I am running a simulation of a tank set up. When animating the video,It flows in the right direction for some few seconds then suddenly it starts moving in the reverse direction. The flow starts moving from the pressure outlet to the velocity inlet. This is not meant to be. Any possible solutions please ? What could be causing this anomaly ?
samoalfred is offline   Reply With Quote
Old   February 9, 2016, 04:40
Nils
Deranda is on a distinguished road
the question is: Does it really flow from outlet to the inlet or does only the animation cause this phenomenon?
Maybe you should plot a vectorScene on a midplane
Deranda is offline   Reply With Quote
reverse flow occur while activating open channel flow boundary? mariam.sara Fluent Multiphase 7 April 26, 2015 08:24
how to get a time-accurate solution in Flow Simulation drdet FloEFD, FloWorks & FloTHERM 4 January 20, 2015 08:11
Reverse Flow at Rotating Pipe Outlet vismech STAR-CCM+ 1 August 11, 2009 11:38
Simulation of flow between two moving plats atnano sachin FLUENT 0 August 28, 2006 00:51
specifying the flow direction in periodic boundary joanna FLUENT 2 February 27, 2006 22:09
