Duct CFM: Velocity (mass flow average) vs Mass flow * Density |
January 27, 2016, 13:57 |
Rep Power: 16 |
Hi, I'm trying to calculate CFM through a fan interface in a simple duct. I have created a report of mass flow and I have density which I can use to calculate CFM. However, when I use mass flow average and generate velocity and then use the area of the fan interface to calculate CFM. They give very different results. Can someone explain which one is more accurate?
January 28, 2016, 16:36 |
Matt
Rep Power: 18 |
If you have incompressible (or nearly incompressible) then dividing mass flow by density is probably your best bet. Using a mass flow averaged velocity essentially biases your average velocity against itself.
To be 100% correct you would want to create a new unit for volume flow rate (CFM). Then define a field function that is the product of area magnitude and velocity (normal to your interface). Then you can get volume flow rate by doing a surface integral of the field function with your interface as your input part. Pay attention to the dimensions of the field function, there is a trap there waiting to trip you up if you aren't paying attention. |
Pressure Outlet Targeted Mass Flow Rate | LuckyTran | FLUENT | 1 | November 23, 2016 10:40 |
Difference between Volume average and Mass flow average? | nygrenm | STAR-CCM+ | 1 | March 2, 2015 13:11 |
Difference between Mass Flow Average in CFX and Mass-Weighted Average in Fluent | dasha | ANSYS | 0 | December 21, 2012 04:41 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
