January 20, 2016, 02:51 |
Spikes occurs in data plots
zhu zhang
Rep Power: 11 |
Hi, everyone!
Recently i'm solving a wedge dropping problem. i applied overset mesh technique and DFBI module to simulate the drop motion of wedge body in a computational domain... However, when checking my result plots, i found some spikes in my pressure results... it means, there are some results are extremely high or low.. For example, the pressure at first time step could be as high as 2kPa... horrible! BTW, i give the wedge body an initial velocity of 3 m/s... so i guess something wrong at discrete momentum eq. or divergence or somewhere.. some numerical conditions: segregated implicit flow... VOF method... laminar... no-slip B.C.. This's reaaaally a headache problem i can't explain... Is there anyone who know this?? Really appreciate it!! |
January 20, 2016, 11:01 |
Matt
Rep Power: 18 |
are your time steps converging?
January 20, 2016, 11:02 |
Matt
Rep Power: 18 |
and is the time step size appropriate?
January 20, 2016, 21:36 |
zhu zhang
Rep Power: 11 |
How to setup a simple OpenFOAM cluster? | TommiPLaiho | OpenFOAM Installation | 3 | October 27, 2013 15:15 |
export data at nodes | Meenu | FLUENT | 1 | December 30, 2011 01:24 |
matching variable data with grid point data | anfho | OpenFOAM Programming & Development | 0 | May 6, 2011 15:28 |
drawing of contour plots | chinthakindi | Main CFD Forum | 1 | April 27, 2004 04:33 |
make an animation plots from the data | colopolo | Main CFD Forum | 4 | September 30, 2003 10:45 |
