DFBI : Ship Motion (roll, heave, pitch) at 30deg beam sea
Old   January 19, 2016, 22:29
Default DFBI : Ship Motion (roll, heave, pitch) at 30deg beam sea
Daniel
dbalan is on a distinguished road
I've been working on a 32m Tugboat (doing calm water resistance). My boss then asked me to do an analysis of the ship at 30 deg beam sea in order to find the resistance and motion of the ship.
When i run the simulation without DFBI (Dynamic Fluid Body Interaction), the simulation just works fine and i am able to find the resistance. WHen i introduce DFBI, my simulation just gets messed up and i would be getting negative volumes after it passes the release time. I'll place an attachment of the scalar scene of it.
All my set up it the same except for orientation of the ship the coordinate system (which i rotated) The regions has remained the same (5 Velocity Inlets 1 Pressure Outlet). For the model i've chosen Implicit Unsteady, Eulerian Multiphase, K-epsilon turbulence, VOF and VOF waves. My meshes remains the same because i was just testing it out. For the DFBI, i've selected z-motion, x-rotation, y-rotation.
This is my first time working with this and I could really use some guidance.
Thanks.
dbalan is offline   Reply With Quote
Old   July 7, 2016, 06:27
Maharashtra
rahulpawar is on a distinguished road
did you solve problem?
rahulpawar is offline   Reply With Quote
Old   November 23, 2018, 11:32
ehsan
ehsanspp63 is on a distinguished road
if you want to simulate ship motion, the ship shouldn't be fixed in all directions meaning that to simulate ship motion just in the vertical plane, for example, it should be free at heave and pitch directions (2dof). Additionally, in such simulations, you must generate 2 mesh zone: a stationary and a moving zone. if you use computational grid used in static simulation in a dynamic simulation, it will definitely be failed because some volume mesh will be collapsed.
ehsanspp63 is offline   Reply With Quote
Tutorial: Heave and Pitch Simulation of Ship hull moving through head sea waves Baxter FLUENT 3 May 2, 2019 05:31
Tutorial - Heave and Pitch Simulation of Ship hull moving through head sea waves Cam FLUENT 6 February 13, 2019 19:12
DFBI Morphing for roll and heave motion Lingfeng Su STAR-CCM+ 0 November 10, 2015 08:08
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
DFBI, turbulence model and ship motion ettax Siemens 1 June 4, 2010 13:31
