Reversed Flow in Outlet
Old   January 13, 2016, 00:40
Default Reversed Flow in Outlet
James
JSped is on a distinguished road
Hi guys,
My simulation uses pipes with "mass flow inlet" at the inlet and "flow-split" outlet at the outlet. Are these appropriate inlet/outlet boundary types for fluid flowing into and out of a pipe?
The reason I ask is that I've been getting two faces of 'reversed flow' at the outlet. How would I remedy this?
I appreciate any help.
JSped is offline   Reply With Quote
Old   January 20, 2016, 04:20
Nils
Deranda is on a distinguished road
in all my simulations, I used a pressure out as boundary conditions and I think thats a common way...
However, if u have reversed flow at your outlet, u have to enlarge the outletarea. For example, if u have a turbulent flow through a pipe and u get reversed flow at the pipes end, u can extrude the pipe by 1m (dont have to be very fine mesh) so the flow can turn into a moderate laminar flow.
By using the extruder in the mesh options u have an easy way to get an enlarged outlet.
The extruder just takes the outlet mesh an extrude the cells.
You have to select your outlet boundary -> extrusion type -> constant normal rate. Then a new tab appears where you can choose your parameters like length, stretching etc...
Deranda is offline   Reply With Quote
Old   January 20, 2016, 11:59
Matt
fluid23 is on a distinguished road
Only use flow-split if you have two (or more) outlets to the system, pressure outlet if you only have one. A mass flow or velocity inlet is appropriate depending on what you are analyzing. As Deranda says, extrude the inlet/outlets. You are seeing re-circulation because your boundary conditions are too close to the rest of your geometry.
fluid23 is offline   Reply With Quote
reversed flow in xxxx faces on pressure outlet franzdrs FLUENT 8 January 4, 2020 21:12
Temperature at a velocity/mass flow outlet saisanthoshm88 CFX 1 July 8, 2014 19:35
Identify Reversed Flow Region on OUTLET gigiboumba CFX 2 June 2, 2014 08:49
reversed flow in the pressure outlet vismayie FLUENT 0 April 27, 2013 03:50
Reversed Flow in Outlet Steve FLUENT 18 March 30, 2013 08:50
