Field FUnction
Old   January 6, 2016, 23:08
Default Field FUnction
Akshay Bagi
akshaybagi is on a distinguished road
Hi, I want to create a field function to measure the shear stress in a fluid flow. I have written a field function but it is not giving me proper values.
The function is
($DynamicViscosity*grad($$Velocity[0]))
I want to use the value from this function to refine my mesh - basically I want to refine mesh wherever the value of shear stress is above some threshold value. When I do the refinement, I cant see any change from the previous mesh.
For mesh refinement, my function is
(mag2($DynamicViscosity * grad($$Velocity[0]))>1.0e-6)?0.75:0
What this does is it changes the cell size to 0.75 wherever the value of the function is greater than 1.0e-6. But I dont see any refinement using this function.
Please help.
akshaybagi is offline   Reply With Quote
Old   January 11, 2016, 16:57
Matt
fluid23 is on a distinguished road
Have you done a scalar plot of your field function to verify that there are values greater than 1.0e-6? Also verify that the units are correct. That could screw things up as well.
fluid23 is offline   Reply With Quote
field function refinement, shear stress, star ccm+
Foam::error::PrintStack almir OpenFOAM Running, Solving & CFD 92 May 21, 2024 08:56
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 07:20
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
