No 3Dimensionality in Flow Past a Cylinder of Subcritical Re # Using RANS
Old   December 9, 2015, 20:24
Default No 3Dimensionality in Flow Past a Cylinder of Subcritical Re # Using RANS
A E
@E18 is on a distinguished road
I am trying to simulate flow past a circular cylinder for Re = 4,000 . For now, I am using RANS models in Star-CCM+. I have noticed that any k-epsilon based models in Star-CCM+ (i.e. SKE, RKE, RSM) do not have any 3 dimensionality. Meaning, there is no amplitude modulations in forces when the phenomenon is model in a 3D configuration and the result of 3D and 2D simulations are almost identical.
In general, the results of k-epsilon models( drag, lift, and Strouhal number) are closer to the experiment compared to k-omega, although the model shows no 3D effects and the values of velocities and vorticity do not change in depth.
On the other hand, using 3D simulations with k-omega results in lower values of drag and lift and amplitude modulation is observed in results.
I do not think it is due to mesh refinement as I have tested different mesh settings and sizes. CFL number is kept less than 1.0 through out the simulation and y+ values are also less than unity.
Anyone has any idea why this happens? Any help is appreciated.
Thanks,
A E
@E18 is offline   Reply With Quote
Old   December 10, 2015, 17:32
Matt
fluid23 is on a distinguished road
I am confused. When you say 3D, you have a finite length cylinder (not semi-infinite) that is giving the same results as 2D? If you have a semi-infinite model (meaning the cylinder spans the thickness of your domain and butts up against a wall or symmetry plane then you should see nearly identical results between a 2D mesh and a 3D mesh. However, if it is a finite cylinder (meaning it has free ends that the fluid can move around them) then you might still get similar results if the L/D is fairly high, although, you would have to be looking at z/L =0.5 (mid span of your cylinder).
Also, unless I miss understand you, the amplitude modulations of the forces are not a result of 2D vs 3D analysis. These are caused by von-karman vortex shedding and should be present for both models.
fluid23 is offline   Reply With Quote
Old   December 10, 2015, 18:37
A E
L/D is 3.0 for the 3D model and the top and bottom boundaries are modeled as periodic interfaces. The response looks like a sinusoidal signal which in reality is not. There should a periodic response with amplitude modulations (the maximum value of forces in a period changes through time). For this range of Re number vortex shedding is a 3D phenomenon and 3D-ness should help get a lower response and amplitude modulation. But I do not see this when I use k-epsilon.
Old   December 10, 2015, 18:41
Matt
k-e is not a good model for separation driven phenomena. Try using k-omega SST and see if that helps.
I am still confused by your choice of words though;
"The response looks like a sinusoidal signal which in reality is not. There should a periodic response with amplitude modulations..."
A sinusoidal response is periodic, isn't it? What am I missing in your explanation?
Old   December 10, 2015, 18:55
A E
Thanks for your quick reply.
I have checked k-w sst and I see the 3D effects in the simulation. But the results are higher than the experiment.
The actual response should be a periodic signal with amplitude modulations while the k-epsilon result is a periodic response with a constant amplitude (no modulations)
k-epsilon k-omega, rans modelling, vortex shedding
Flow past a cylinder, Reynolds No: 100, Tracking strouhal Number. Karan FLUENT 11 November 14, 2016 05:49
Flow past rotating cylinder sam.ho OpenFOAM Running, Solving & CFD 4 October 10, 2013 08:49
Flow past a cylinder. Help needed Lurapa Main CFD Forum 1 August 18, 2013 12:25
Flow around a cylinder at subcritical regime. yousef FLUENT 0 March 18, 2006 10:18
meshing for flow past a cylinder karthik FLUENT 1 July 15, 2005 07:17
