November 15, 2015, 04:42 |
Monitoring a value with alternating sign
Chan Hiang Bin
Rep Power: 13 |
As describe in the title, I would like to set a report to monitor a displacement that is changing with time. Its value could be positive and negative. I have set a maximum report to monitor the value but it is only capable to monitor the values that are greater than 0. Currently, I have two reports (1 max and 1 min) just to monitor the displacement for a single point. Monitors.png Therefore, I would like to ask whether monitoring both positive and negative values at the same time is possible? What type of report should I select? Regards, Bin |
November 20, 2015, 01:15 |
Rep Power: 24 |
If you are really reporting a single point probe's displacement, the maximum and minimum reports should return the same identical value. A maximum or a minimum of a single value is just that value.
Sign convention when computing moments | Jeremie84 | FLUENT | 1 | April 5, 2021 14:38 |
Herschel-Bulkley non-Newtonian viscosity model has term with sign error | pbryant | OpenFOAM Bugs | 5 | June 18, 2013 23:53 |
Sign of massflow across a plane | Chander | CFX | 6 | June 14, 2012 03:36 |
the sign "temperature limited to sth..." | Kwang | FLUENT | 0 | October 21, 2007 06:18 |
monitoring cell | Jane | Siemens | 2 | March 4, 2004 21:01 |
