Radiation - Solar Loads - Material properties |
November 9, 2015, 11:59 |
Rep Power: 11 |
Hi everybody,
i try to simulate the irradiation on a solar thermal collector. After activating radiation>s2s radiation>solar loads i am now struggeling with the "Physics Values" for the surface where the energy should be absorbed. Basically it is a alloy plate and i can change the "Emissivitiy" and "Transmissivity" of the selected "Boundary". I am wondering why it is not possible to specify the "absortion coefficient". Can anyone please help because at the moment i have no idea how to prescribe the absorption on that surface. Thanks a lot! |
November 9, 2015, 15:29 |
Rep Power: 25 |
Transmissivity, reflectivity, and absorption are all coefficients that must add to 1. You can specify transmissivity and reflectivity to give you a certain absorption.
November 10, 2015, 03:43 |
Rep Power: 11 |
Thanks! I was trying it that way but the plate is not heating up at all. Maybe i should use the the multiband thermal radiation instead of the gray thermal radiation so i can define the tranmissivity etc. for different wave lengths. I was just wondering because there was no increase in temperature..
November 10, 2015, 12:05 |
Rep Power: 25 |
Perhaps your boundary is just in shadow? If you plot the boundary irradiation is it nonzero?
November 11, 2015, 10:04 |
Rep Power: 11 |
Ok, now it is working. Thanks
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 22:43 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 06:21 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Constant velocity of the material | Sas | CFX | 15 | July 13, 2010 09:56 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
