field function max
Old   November 5, 2015, 15:50
Default field function max
Alberto
Alberto Damas is on a distinguished road
Hello.
I want to define a field function using the maximum value of another field function. ¿is this possible?¿how would it be?
Thx.
Alberto Damas is offline   Reply With Quote
Old   November 5, 2015, 16:27
Matt
fluid23 is on a distinguished road
step 1: create a report for the field function for which you want the maximum. you can set this up to give the max value anywhere in the domain, anywhere on a specific surface, or on a derived part.
step 2: create a user defined field function that calls your maximum report. Lets assume you called it 'max', you can call it inside the field function using $maxReport.
fluid23 is offline   Reply With Quote
Old   November 5, 2015, 16:30
Alberto
Thx a lot. That's exactly what I need.
field function, max, maximum
y+ and u+ values with low-Re RANS turbulence models: utility + testcase florian_krause OpenFOAM 114 August 23, 2023 06:37
Cavitation around NACA hydrofoil using interPhaseChangeFoam Kozan OpenFOAM Running, Solving & CFD 28 March 12, 2023 00:30
''unknown radialModelType type Gidaspow'' PROBLEM WITH THE BED TUTORIAL AndoniBM OpenFOAM Running, Solving & CFD 2 March 25, 2015 19:44
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
