Engine Bay Temperature Convection Modelling
Old   October 25, 2015, 07:32
Default Engine Bay Temperature Convection Modelling
Rob
luckyrob is on a distinguished road
Having made use of the 'Search' function but had no joy I thought I should post a question to maybe get some help.
I am attempting to model a simplified engine bay of a car in order to assess the cooling effect that different cooling inlet and outlet openings will give. I am not so interested in the engine component temperatures as I am the air within the engine bay.
The problem I am having despite following the Graphics Card and Exhaust Manifold tutorials created by CD-Adapco, is that I seem to get either no, or very little heat transfer to the air surrounding the engine.
If I simply set the engine Continua to a temperature then no transfer occurs. If I leave the Continua temp to ambient and set the engine Region-Heat Source Option to Total Heat Source and then assign a Heat Source value in Watts I get some transfer.
The problem with this is I only get transfer very close to the engine/air interfaces and more importantly I have no idea how to give the engine a realistic Heat Source value! Along with this, the temperature of the engine gets hotter with every iteration and never converges.
I'm sure I am doing something very simple incorrectly, so if someone could point me in the direction of some useful information I would be extremely grateful.
ps. Not sure if it will make a difference but I am running a Steady simulation as as I want to see the effect at a certain vehicle speed
luckyrob is offline   Reply With Quote
Old   October 25, 2015, 17:09
me3840 is on a distinguished road
If the engine keeps getting hotter then your simulation is not converged and you have to run it longer. How long are you currently running it, and how large is the mesh?
Ensure you have a good prism mesh around the engine and that the interface from solid to fluid has good matching (99.9% or better).
me3840 is offline   Reply With Quote
Old   October 25, 2015, 19:55
Rob
Thanks for the advice........I'll get onto checking the quality of my mesh (as I am not sure that it is 99.9% matching) and let you know how I get on.
Old   October 29, 2015, 14:52
Rob
Thanks for pointing me in the right direction................
My mesh was not aligned very well at the interfaces; this was due to me not using a polyhedral mesher and because I was using a trimmer. Or at least that is what some research suggested the reason for the interfaces not mating properly was.
The simulation has since converged within 600 iterations.
Much appreciated
[openSmoke] libOpenSMOKE Tobi OpenFOAM Community Contributions 562 January 25, 2023 10:21
convection reference temperature Dyls Siemens 0 May 21, 2014 14:06
Thermophysical properties for natural convection Ciefdi OpenFOAM Running, Solving & CFD 0 November 7, 2013 12:44
Temperature Drop Modelling wateraction FLUENT 2 February 29, 2012 07:56
modelling airflow through an inlet restrictor on a four stroke engine mike ede Main CFD Forum 0 October 8, 1999 10:06
