Vertical Axis Wind Turbine (VAWT) verification
Old   September 10, 2015, 06:16
Default Vertical Axis Wind Turbine (VAWT) verification
Nguyen Ba Hieu
bahieu is on a distinguished road
Hi everyone,
I am a Master student. Now I have some problem with my VAWT verification for this paper "2D CFD Modeling of H-Darrieus Wind Turbines Using a Transition Turbulence Model"
http://www.sciencedirect.com/science...76610214000162
I using sliding mesh method, SST k-omega turbulence model.
Total number of grid is 180,000. Y+<1
However, the results show a big difference with the reference.
Here is some Figure of my mesh and the results.
If anyone have any experience of suggestion, please help me
Thank you!
bahieu is offline   Reply With Quote
Old   September 10, 2015, 09:33
Matt
fluid23 is on a distinguished road
I suspect that your sliding mesh is not allowing for a realistic flow condition to exist. I encountered something like this many years ago using what was at the time called CFDesign. It turned out that having this huge disk of rotating mesh was essentially dragging the air around with the turbine in a way that didn't actually represent any real flow condition. Granted that software was fairly limited compared to Star-CCM.
Looking at the paper you posted, I wonder if you aren't seeing the same kind of issue. I see that their rotating mesh region is a donut shape and not a full disk. Try a setup similar to this and see if you don't get better results.
fluid23 is offline   Reply With Quote
Old   September 10, 2015, 22:41
Nguyen Ba Hieu
Thanks, Mr. Matt
I have tried the mesh as your suggestion. But, the results is similar.
Old   September 11, 2015, 04:23
Default calculate torque in VAWT
Arash Mahboubidoust
arashfluid is on a distinguished road
Send a message via Yahoo to arashfluid
Hi friends,
I have simulated the 2D Darrieus wind turbine by pimpleDyMFoam.
To calculate the forces and moments coefficients for every blade I have added similar code in controlDict file, but I'm not sure about lRef and Aref in VAWT;
I've seen them with different definitions in different references.How could I calculate their correct values?
forceCoeffs1
type forceCoeffs;
enabled true;
functionObjectLibs ("libforces.so");
patches ("airfoil1");
pName p;
UName U;
rhoName rhoInf;
rhoInf 1.225;
CofR (0 0 0);
liftDir (0 1 0);
dragDir (1 0 0);
pitchAxis (0 0 1);
magUInf 5.0; //wind speed
lRef 1.0; //rotor length or chord?
Aref 2.0; //rotor length* rotor diameter or chord*rotor length?
outputControl timeStep;
outputInterval 10;
I want to extract moment instead of momnet coefficients as much as possible, because I can directly calculate the cp. But data do not store in a regular basis.
I want a suggestion for saving moments data regularly and extraction torque curve over time.
Thanks a lot,
Best regards,
Arash.
arashfluid is offline   Reply With Quote
Old   July 30, 2016, 20:55
Muhammad
Lprince is on a distinguished road
I'm working on the same paper facing the same problem as TSR increases the power coefficient increases .. although I followed this paper step by step ..
Lprince is offline   Reply With Quote
Old   February 20, 2018, 07:52
Ahmed Mustafa ahmed el.attar
Ahmed attar is on a distinguished road
Any luck to solve this problem
I am working on 2d vawt simulation and having the same problem as the tsr increases the cp increases
Ahmed attar is offline   Reply With Quote
Old   March 18, 2020, 06:32
usr0830 is on a distinguished road
I am performing 2D VAWT simulations on Openfoam with a setup similar to the one mentioned in 2D CFD Modeling of H-Darrieus Wind Turbines using a Transition Turbulence Model. I face the same issue with the Cp values continuously increasing with increasing TSR. If anybody has solved the same issue, could you please give me some suggestions.
Thank you.
usr0830 is offline   Reply With Quote
High torque coefficient Cm for Vertical Axis Wind Turbine (VAWT) tony00 FLUENT 11 July 23, 2018 07:13
Vertical Axis Wind Turbine f.gig Fidelity CFD 4 May 30, 2014 10:57
Vertical Axis Wind Turbine atorninc Main CFD Forum 3 March 6, 2013 05:38
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 04:14
Vertical axis wind turbine in NUMECA ArslanOZCAN Fidelity CFD 2 July 21, 2011 06:04
