Rep Power: 12 ![]() |
I've been attempting simulations of unsteady flow in an urban environment. Using a k-e turbulence model and segregated flow model, I've been able to get good results for a steady solution.
However, when I try to use implicit unsteady to generate unsteady flow within my environment, the solution tends to the steady state form over large periods of time, with no transient properties. If I try to initialise the simulation with a steady state solution, there are still no changes with time. I'm still using the k-e model, which I realise by definition is time-averaged but shouldn't I still be seeing some kind of change? |
Rep Power: 24 ![]() |
Not necessarily; if the problem doesn't have enough transience in the physics then an unsteady solution will become steady given time. However, you could also have a coarse enough grid or timestep to filter out the unsteadyness artificially.
Thanks for your response. I've been out of the office so apologies for the delay... I switched to DES with the Spalart-Allmaras model and achieved success, however, I use that term loosely. Unsteadiness was developed throughout the domain and it appears reasonable. However, there doesn't seem to be a lot of available data for validating unsteady urban flows so I'm still in the dark a little bit.
implicit, k-e model, unsteady |
Problem with pimpleDyMFoam: Initialise steady state solution | Lancester | OpenFOAM Running, Solving & CFD | 2 | September 29, 2015 09:49 |
is it possible to predict how long it takes to reach steady state solution in unstead | Alimohamadi_nasr | CFX | 4 | November 11, 2013 06:11 |
Steady solution from Transient simulations | wawa | FLUENT | 2 | November 9, 2010 17:44 |
shifting from Unsteady to steady | Abhinav | FLUENT | 0 | July 29, 2007 22:53 |
about the steady solution | zwdi | FLUENT | 0 | August 29, 2003 10:34 |
