August 28, 2015, 18:07 |
Wind Turbine, polyhedral mesh
André Luiz Moura Silva Moreira
Rep Power: 11 |
I'm trying to simulate a wind turbine. In the region near the turbine my cells have varying sizes. I wanted more uniformity in this region, but I can not do it. Can anyone help me to leave my more uniform mesh?
Well, this mesh is good? Thanks for you help. |
September 1, 2015, 13:15 |
Matt
Rep Power: 18 |
First thing I would do is reduce the surface mesh on your turbine surfaces. Part of the reason that you see that line of fine cells with much large cells behind it is that you have too large of a gap between your large and small surface mesh sizes.
Your prim mesh is constructed from your surface mesh, so basically you need to limit what it can grow to near the turbine by changing the size of the turbine surface mesh. Another thing you can try after fixing your surface mesh is to customize the prism mesh tet/poly density and tet/poly growth rate parameters. |
September 21, 2015, 08:43 |
Rep Power: 11 |
Thank for your help, this solved my problem.
Gambit problems | Althea | FLUENT | 22 | January 4, 2017 04:19 |
CFD analysis on wind turbine rotor | Ken (Wind Turbine CFD Super Rookie) | Main CFD Forum | 45 | February 9, 2016 15:07 |
[ICEM] 3D Wind turbine mesh | luxingzhe | ANSYS Meshing & Geometry | 16 | May 17, 2012 06:40 |
Polyhedral Mesh Quality in Star-CCM+ | niazaliahmed | STAR-CCM+ | 3 | March 8, 2012 14:51 |
How to Mesh For Wind Turbine Blades for CFD Simulation in Hypermesh? | haristrawberry | Main CFD Forum | 3 | November 12, 2010 07:27 |
