August 5, 2015, 01:41 |
Duplicate scene in multiple simulation cases
John Bulzacchelli
Rep Power: 12 |
I am wondering if there is a way to automate scene creation between multiple simulations. In my case, I have multiple simulations of the same assembly, just with one component's position slightly changed. I would like to be able to set up my scene in one simulation, and apply it to all cases to speed up my post-processing time. Thanks, John |
August 5, 2015, 03:28 |
Rep Power: 11 |
Hi John,
You should be able to this if the naming is the same for the ingoing parts in the scene (parts, regions, derived parts etc..), if you have both cases opened at the same time, you should be able to just copy and past the scene into the other simulation case. Hope that this works for you! |
August 6, 2015, 23:10 |
#3 | |
John Bulzacchelli
Rep Power: 12 |
You've saved me hours of tedious work! |
August 10, 2015, 15:49 |
Matt
Rep Power: 18 |
FYI: You can copy just about everything that way. Not just scenes.
Also, a more direct and editable approach would be to use macros. Simply record the creation of one, then run the macro in the rest. Easy as pi. |
plot, post-processing, scene |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
Use homogeneous results as the initial guess for an inhomogeneous simulation | JuPa | CFX | 5 | December 26, 2014 14:44 |
setting up a simulation with multiple interactions | phandy | OpenFOAM Running, Solving & CFD | 1 | October 6, 2014 04:16 |
Blunt body aerodynamics simulation cases needed | David | FLUENT | 0 | June 1, 2003 12:40 |
3-D Contaminant Dispersal Simulation | Apple L S Chan | Main CFD Forum | 1 | December 23, 1998 11:06 |
