CDLMD_LICENSE_FILE error
Old   August 3, 2015, 09:09
Default CDLMD_LICENSE_FILE error
ktytagong is on a distinguished road
Hi everyone,
I have a problem with CDLMD_LICENSE_FILE.
then I tried to solve followed this
when I typed "env | grep LM", I got the same result as them.
But when I run the program, I still have the same problem.
Does anyone have any suggestion how to fix this problem?
Ps. I use linux system.
ktytagong is offline   Reply With Quote
Old   August 4, 2015, 13:27
hxaxtma is on a distinguished road
Please try following command in a terminal
1) First of all what license do you have? An own license from your company or do you use a license on demand from cd-adapco
2) are your licens path inferomation right? this means address and port number
3) Check the connectivity with following command (terminal)
telnet urlofyourlicensepath portnumber
for example
telnet flex.cd-adapco.com 1999
As result should appear a message with "connected"
If not check your firewall and router options, is it allowed to connect to this port and so on....
In companys it is often restricted and you are not allowed to connect through this port, therefore talk to your IT department
P.S.: The env | grep LM command just only says that you set an environmental variable with LM inside, this does not say anything about connectivity
P.P.S.: And I think your openmpi is not compiled in right way, maybe wrong user rights. Single core shoudl be possible, multiple core not! Try it!
hxaxtma is offline   Reply With Quote
license, starccm+
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 19:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
