negative velocity inlet
Old   July 22, 2015, 11:51
Default negative velocity inlet
hebeldebel is on a distinguished road
I wrote a field function to control the inlet velocity of a boundary:
cos(${Time}*2*3.14*2)*10
It works until the velocity reaches 0 and then rises again, I never get a negative velocity at the inlet. I ran reports, which showed that the output of the field function was indeed negative, but Star CCM+ turned it into a positive value for the velocity inlet.
It seems like a velocity inlet cannot be used as an outlet by simply putting a minus in front of the value. What would you do to accomplish this?
kind regards,
hebeldebel
hebeldebel is offline   Reply With Quote
Old   July 22, 2015, 17:33
Matt
fluid23 is on a distinguished road
maybe try using a mass flow inlet? I know those can go negative.
honestly, this seems like a bug. you may want to submit it to CD-Adapco so they can resolve it.
fluid23 is offline   Reply With Quote
How to define a fixed velocity for a given mass flow rate on inlet mqasimali FLUENT 2 April 12, 2013 18:24
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 14:06
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
