Bump in flat plate boundary layer
Old   July 13, 2015, 11:17
Default Bump in flat plate boundary layer
DCK
DCK is on a distinguished road
Hi Everybody,
I am a beginner to CFD. I tried to simulate the flow over a flat plat, i.e. simulate the LAMINAR boundary layer to compare it with the BLASIUS solution. The velocity at the inlet is 1 m/s. The attached plot shows the velocity profile at 1m downstream of the leading edge.
If you look at the flow well outside of the boundary layer (let's say y>0.15 m), you see that the velocity is at around 1.01 m/s instead of the 1.00 m/s I specified. Does this make sense? I wondered if this is due to the fact that I set up a wind tunnel in CCM+, modeling the floor as a wall, and both side walls as well as the ceiling as a symmetry plane. Hence, to maintain overall mass continuity, the flow outside of the boundary layer needs to be a bit faster than the freestream velocity, to make up for the smaller velocities in the boundary layer. Am I correct?
What I do not understand at all is the bump around 0.02 m < y < 0.1 m. Where does this come from? Is there a physical Explanation? Or is this an error due to some mistake(s) I made setting up the simulation?
Regards
Daniel
DCK is offline   Reply With Quote
Old   July 22, 2015, 11:02
Matt
fluid23 is on a distinguished road
is this a RANS anlaysis? if so, what turbulence model are you using? what wall treatment? is your y+ appropriate? it looks like your boundary layer isn't resolved all that well, but without seeing your mesh I can't say for sure.
we need more information to determine a cause.
fluid23 is offline   Reply With Quote
Old   July 23, 2015, 02:55
DCK
it's a RANS analysis without turbulence modeling, i.e. the flow is modeled as being laminar. I think I found the reason: I placed the leading edge of the flat plate immediately downstream of the inlet face. Meanwhile I found out that this should not be done. Instead, i placed a slip plate right at the beginning of the flow region, and then I attached the flat plate (no-slip wall of course) downstream of the slip plate. Now it works!
Boundary layer over a flat plate using CFD hsnclk Main CFD Forum 5 April 30, 2020 10:34
Flat plate and Boundary conditions Ravenn FLUENT 1 March 10, 2013 19:39
Questions about Boundary Layer Thickness and Turbulence Models famerfamer STAR-CCM+ 3 July 12, 2012 10:47
Flat plate boundary layer problem student Main CFD Forum 3 May 21, 2007 14:10
errors Fahad Main CFD Forum 0 March 23, 2004 14:20
