How to create a time delay for inlets?
Old   July 5, 2015, 13:19
Default How to create a time delay for inlets?
Danny
danny21 is on a distinguished road
I am having some trouble with a simulation that I am running. I am running a multi element wing for a Formula One style car in a fluid domain with the obvious Inlet, outlet, symmetry planes, and ground plane. However, I also have a small cut in the bottom of the main plane that I want to be an inlet. The thought behind the design is that if you can get air moving faster out of the inlet, you can lower the pressure which creates more downforce.
The problem that I am running into is that I am getting reversed flow even though the air is flowing in the same direction as the fluid domain inlet. I looked towards the streamlines to find some answers. The only idea I saw was that it started flowing before the fluid domain inlet reached it.
Any ideas?
Thanks,
Danny
danny21 is offline   Reply With Quote
Old   July 6, 2015, 03:09
kris
kguntur is on a distinguished road
Hi Danny,
Could you be a little more specific? Where is this 2nd inlet? Are you running transient or steady state? How long are you getting the reversed flow?
From your title I assume you want to the inlet velocity to be 0 initially and then at a perticular time or iteration you want to increase the velocity. You can use field function to achive this.
Hope this helps.
-Krishna.
kguntur is offline   Reply With Quote
Old   July 9, 2015, 22:27
Danny
Hi Kirshna,
Thank you for the reply.
I am running a steady state simulation and I am getting flow reversal and the conjugate gradient is unable to converge. The second inlet is on the under side of the wing. I made a cut in the bottom so that the inlet would point tangent to the wing.
I would like the air from the 2nd inlet (under the wing) to be delayed until the air from the front of the fluid domain reaches it so that it simulates the interaction between the two. For example the car driving along at a steady state and the air coming out from under the wing. I've uploaded some pictures that I hope will help.
I have not dealt with field functions and I was wondering if you could either explain how you would go about doing that or point me towards a tutorial that would explain it? I've found a lot that explain how to refine surfaces.
Best Regards,
Danny
Old   July 14, 2015, 20:02
Danny
Bump for attention
Old   July 16, 2015, 09:29
Gajendra Gulgulia
ggulgulia is on a distinguished road
Hi Danny
I am curious to know the relative locations of the two inlets and the outlet. Is the 2nd inlet opposite to the first one, at the tail of the wing? What exactly is the boundary condition at both the inlets?
Also you should try converting the 2nd inlet as outlet and monitor how much mass flows out of the boundary, the pressure there. The values that need input when using the same as inlet boundary should be more than what you get when you run trial with outlet boundary.
Where exactly are you getting Reversed Flow? (CCM+ output window will give the name of the boundary that has reversed flow)
Thirdly you will have to resort to transient simulation if you want to introduce a delay b/w the inlets of the two boundaries
Hope this was helpful
ggulgulia is offline   Reply With Quote
reverse flow, reversed faces, star ccm, wings
Transient simulation not converging skabilan OpenFOAM Running, Solving & CFD 14 December 17, 2019 00:12
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
same geometry,structured and unstructured mesh,different behaviour. sharonyue OpenFOAM Running, Solving & CFD 13 January 2, 2013 23:40
Actuator disk model audrich FLUENT 0 September 21, 2009 08:06
Where's the singularity/mesh flaw? audrich FLUENT 3 August 4, 2009 02:07
