Question on CFD+DEM Coupling Simulation Using STAR-CCM+
Old   June 23, 2015, 16:36
Default Question on CFD+DEM Coupling Simulation Using STAR-CCM+
Junhong Li
John Lee is on a distinguished road
Dear all,
I have problem simulating a channel flow over some layers of particles using a CFD+DEM model.
My model is like this: On the bottom of a flume, I place a certain thickness of randomly-packed particles. Then I assign the inlet as a velocity boundary and the outlet as a pressure outlet.
The purpose is to: study the sediment erosion in the channel.
The problem is: Although the model seems running successfully and particles start to move when the fluid velocity reaches a certain magnitude, the simulation results are suspicious to me. At least, I can't validate them with existing experimental studies. In my simulation results, the fluid velocity within the particles never reaches zero. I do expect that there is some internal flow within the particles. However, the internal flow should be within some distance below the top surface, beyond which the fluid will be difficult to penetrate. But based on my simulation results, the fluid velocity field within the particle bed is some kind of chaos and never dissipates gradually to zero. It feels like that these solid particles have no blocking effect for fluid penetration.
Any idea on this problem is greatly appreciated. Thanks for your time!
Sincerely,
John
John Lee is offline   Reply With Quote
Old   June 27, 2015, 12:21
me3840 is on a distinguished road
Are you running double-precision? If you're just getting noise in the bed that's what you may be seeing. What is the velocity magnitude in the bed?
me3840 is offline   Reply With Quote
importing ducted fan from catia to star ccm Daniel4 STAR-CCM+ 0 November 3, 2014 10:34
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
Compressor Simulation in Star CCM+ chili023 STAR-CCM+ 13 August 11, 2011 03:22
CFD-analysis of hydroplane: STAR CCM or Flow Simulation? peterg07 Main CFD Forum 0 February 7, 2010 15:32
[Other] StarToFoam error Kart OpenFOAM Meshing & Mesh Conversion 1 February 4, 2010 05:38
