June 4, 2015, 17:55 |
Surface Wrapping with gap closure
I'm trying to close holes by doing a surface wrap. It's not an option to use a target surface size bigger than the hole size because i want to achieve an accurate wrapping. To close the holes, I activated "Perform Gap Closure" in the Surface Wrapper Properties and entered a suitable Gap Closure Size. Unfortunately, this doesn't affect the result. The holes remain in the surface. Could you please tell me, why this doesn't work and how I can make it work? |
June 30, 2015, 00:06 |
Rep Power: 25 |
Generally I avoid gap closure. It's much easier to ensure you get what you want by either filling or patching over holes. Load up your geometry in surface repair and patch/fill holes to get what you need.
gap closure, surface wrapping |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
Simulation of varying contact angles for a large droplet of water on a surface | cp703 | CFX | 5 | July 20, 2013 07:08 |
Comsol (4.3): convert parametric surface into block? | sgalaz | COMSOL | 0 | November 9, 2012 10:20 |
CCM+: Surface Wrapping Tutorial | Peter Specht | Siemens | 9 | March 13, 2008 11:11 |
surface wrapping takes forever | Kiran | Siemens | 3 | October 13, 2006 14:01 |
