How to plot `turbulent intensity' in Starccm+
Old   May 6, 2015, 10:04
Matt
fluid23 is on a distinguished road
That depends on the wall treatment you are using, the level of accuracy you want and many other factors. The ranges I gave are very broad and loose. If you want to be as accurate as possible use the near wall model and keep your y+ values as close to 1 as you can. Obviously, in most cases it would require cell by cell modification of the mesh to acheive that which you cannot do in star-ccm+. However, you should be able to keep it fairly constrained in a straight pipe like this.
I suggest you read up on the wall treatment methods to understand the specifics. The help docs have good discussions of each one.
fluid23 is offline   Reply With Quote
Old   May 6, 2015, 10:16
ktytagong is on a distinguished road
Thank you very much
ktytagong is offline   Reply With Quote
Old   May 6, 2015, 12:41
I got a problem again.
According to the field function, I did follow what you said.
Apparently, I got 'Turbulent intensity field function: Floating point exception [divide by zero]Turbulent intensity field function: Floating point exception [divide by zero]'
Then I could not add the function of turbulent intensity
Old   May 6, 2015, 12:58
Matt
The function is added, but it is blowing up because of the zero velocity in the boundary layer. That was an oversight on my part. For now you can just make it:
sqrt(2/3*${TurbulentKineticEnergy})/mag($${Velocity}+0.0001)
I am looking to see if I can make it a conditional statemtent to set Intensity to zero if velocity is zero. The equation above should be accurate enough though. You will get high TI anywhere you have zero velocity like the BL, but should be fine in the core flow. That 0.0001 will not impact anything out there.
Old   May 6, 2015, 13:37
Matt
Use this:
mag($$Velocity)==0 ? 0:sqrt(2/3*${TurbulentKineticEnergy})/mag($${Velocity})
Old   May 6, 2015, 13:40
I will try and update again tomorrow
Thank you very much
Old   July 9, 2015, 08:24
Default Hello
  #27
Deutschland
sarvesh34 is on a distinguished road
Hello
Can anybody help how to define the code for
(Outlettemperature-Liquidtemperature)/(InletTemperature-LiquidTemperature)
For field Function named Temperature Distribution.
I am New here..
Thanks in advance
sarvesh34 is offline   Reply With Quote
Old   July 9, 2015, 09:42
Matt
First, I am assuming you want this to be calculated for every cell not averaged for the whole fluid. If that is wrong let me know...
Create 2 Reports:
1. Mass Flow Averaged Temperature at Inlet (boundary only), call it InletT
2. Mass Flow Averaged Temperature at Outlet (boundary only), call it OutletT
Create a Field Function:
1. Right-click tools > field functions and select new > scalar.
2. Rename the field function and the function name in the properties window to 'Temperature Distribution'.
3. Leave dimensions as 'dimensionless' since you have T/T.
4. Set the definition to ($OutletReport - $Temperature)/($InletTReport-$Temperature)
It should then appear anywhere you can select scalr field functions (scenes, reports, monitors, etc...). You can treat it just like any other variable.
Old   July 9, 2015, 11:46
Deutschland
Thank You very much
I will try it and post if there are any problems
Old   October 5, 2015, 12:08
Bin
Chan Hiang Bin
Bin is on a distinguished road
I have a question. I understand that we need to check the y+ value based on the selected wall treatment. Use low y+ wall treatment as example, the desire y+ should be 1 to 5. y+>5 is definitely not recommended, but how about y+<1?
Bin is offline   Reply With Quote
Old   October 5, 2015, 14:37
hwsv07 is on a distinguished road
for the cells right next to the wall, y+ should be less than 5 in order for the viscous sublayer to be sufficiently resolved.
of course you can have very small y+, less what you suggested i.e. <1. however, this would mean excessive computation time.
hwsv07 is offline   Reply With Quote
Old   October 6, 2015, 04:56
Bin
Chan Hiang Bin
This means it won't cause anything bad even the y+ is out of the recommended range (i.e. 1 to 5), just the computation time will be increased?
Old   October 6, 2015, 06:48
yes.
consider an unsteady simulation. of course, you can have a timestep size that is infinitely small. but what for? you probably can still can get the same result in a reasonable amount of time at a sufficiently large timestep.
Old   October 7, 2015, 09:20
Bin
Chan Hiang Bin
yes.
I see. Thank for the explanations.
Old   October 15, 2015, 12:08
Bin
Chan Hiang Bin
Originally Posted by MBdonCFD View Post
Use this:
Apart of writing this field function, how about monitoring the variance of velocity [i,j,k]? As far as I know, variance is the second moment of the flow field, means it is (u`)^2; (v`)^2; (w`)^2, which can represent the fluctuaing component. Am I right?
graphic, result, starccm+, turbulence intensity
[swak4Foam] Foam warnings - related to swak4Foam Salam-H OpenFOAM Community Contributions 20 August 2, 2015 16:40
Question on Turbulence Intensity Eric FLUENT 1 March 7, 2012 05:30
About Turbulence Intensity (Pipe flow assimilated) gRomK13 Main CFD Forum 1 July 10, 2009 04:11
Loss of Contour Plot colour intensity Bou Siemens 3 June 13, 2007 21:19
graph plot anindya Main CFD Forum 2 September 17, 2003 13:00
