Periodic boundary conditions for moving reference frame (MRF) simulation) |
April 14, 2015, 11:33 |
Bettina
Hej!
I'm new to starccm+, trying to set up a moving reference frame simulation for a hydrodynamic bearing (spiral groove bearing). Since I don't want to simulate the whole bearing (too high computational cost), I imported the geometry of only 36°-part, which should be rotationally repeated (10x). With tutorials I got as far as setting up periodic interfaces for the boundaries... Does anyone have experience on which physics conditions/values I have to set for the periodic interface? The fluid should not be driven by a pressure jump or mass flow, but just by the rotating part (i.e. the part in MRF) above the bearing. I did try it with setting the pressure jump to 0.0Pa (zero), but the simulation didn't converge... Thank you! |
April 15, 2015, 07:55 |
Gajendra Gulgulia
Rep Power: 13 |
Hi
Periodic boundaries are used to mirror the flow fields from one boundary to another amongst the boundaries in the interface. They do not need any physics condition per se. I guess you are trying to simulate 3d axisymmetric case where I do not see any moving reference frame fitting in the bearing simulation. |
December 20, 2024, 09:24 |
Ashish
Hello, were you able to come up with a solution? @guebelib
moving reference frame, periodic interface |
Rotation Reference Frame Boundary Conditions | Brathmann | FLUENT | 4 | April 30, 2013 03:31 |
parallel code | samiam1000 | SU2 | 3 | March 25, 2013 05:55 |
CFX does not continue | Shafiul | CFX | 10 | February 17, 2011 08:57 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
