Changing the Angle of Attack in Star-ccm+
Old   March 26, 2015, 07:46
Default Changing the Angle of Attack in Star-ccm+
Alexander Small
AlexSmall90 is on a distinguished road
I have recently started using Star-ccm+ for a university assignment and I have reached a point where I need to adjust the angle of attack to perform the next set of simulations.
I am performing CFD on a wing and have so far only tested three airflow velocities at 0 degrees but now I need to test the same three velocities at -15 degrees and +15 degrees angle of attack.
I have seen online that you can adjust the angle of the inlet but I need to adjust the angle of attack of the wing for the purpose of this assignment.
Any help would be much appreciated.
Thanks,
Alex
AlexSmall90 is offline   Reply With Quote
Old   March 26, 2015, 10:34
Matt
fluid23 is on a distinguished road
Why do you have to adjust the wing? That is more work than changing a boundary condition. If you must rotate the geometry rather than cange a couple of inputs then you can just right click on the part and select transform > rotate. You will have to remesh though.
Simply updating the components of your freestream velocity is a much cleaner way of doing this.
Are you trying to compare to experimental data at 15 degrees? Might be tough with little to no experience.
fluid23 is offline   Reply With Quote
[PyFoam] Problems with the new PyFoam release zfaraday OpenFOAM Community Contributions 13 December 9, 2014 19:58
[PyFoam] having problems with pyfoam Installation vitorspadetoventurin OpenFOAM Community Contributions 3 December 2, 2014 08:18
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
