How ot plot pressure over an object surface?
Old   March 25, 2015, 11:29
Default How ot plot pressure over an object surface?
Anon
vilius is on a distinguished road
I have an assignment where I must plot the pressure over an object surface in a single plane (centre of the object). For example if I run a simulation on a square, and I want to find out what the pressure on the surface of the square is in just the centre plane, how would I do this?
Ideally I would like Star CCM+ to create the plot, or more preferably give me coordinates which I can use to plot a graph myself.
Edit: I am also very new to Star CCM+ and I'm not much sure how to use it
vilius is offline   Reply With Quote
Old   March 25, 2015, 16:49
Matt
fluid23 is on a distinguished road
Create a derived part > section > plane. Assign the part you want to look at and place it at the correct location with the correct normal vector. Then create a new scalar scene, hide the outline displayer and change the parts selection under the scalar displayer to derived parts > plane section. Depending on your view, you may have to rotate to see it.
fluid23 is offline   Reply With Quote
Old   March 25, 2015, 16:50
Matt
Also, don;t forget to assign pressure as your field funciton under Scalar displayer > Scalar Field.
star ccm
SampleDict Pressure Plot across a wing chord 70m1 OpenFOAM Running, Solving & CFD 5 July 5, 2021 19:33
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible velan OpenFOAM Meshing & Mesh Conversion 3 October 22, 2015 12:05
Calculating forces on a non-closed surface ScottN FLUENT 0 March 1, 2011 18:18
[Gmsh] boundaries with gmshToFoam‏ ouafa OpenFOAM Meshing & Mesh Conversion 7 May 21, 2010 13:43
Does star cd takes reference pressure? monica Siemens 1 April 19, 2007 12:26
