how to find the angle of attack in the wind turbine blade |
March 9, 2015, 14:15 |
lin lin
Rep Power: 11 |
Dear all,
I calculated a 3D floating wind turbine, so the angles of attack are different in every time and every element. how can I get the angle of attack or flow angle in every section of the blade. Thanks |
March 9, 2015, 15:20 |
Matt
Rep Power: 18 |
You probably cannot if you have actual 3D geometry modeled. As you are probably aware, as the air approaches the blades it moves in response. Therefore there is no point in the flow field you can exract velocity vectors from to determine AOA.
There is a tool in star-ccm+ that may help you get the answer you are after, but I am not sure if you can get the spanwise distribution of AOA back out. It's called the blade element virtual disk. If you are a wind turbine engineer, then you are probably aware of blade element momentum theory, yes? Well, star has coupled BEM theory with a momentum source. Here you specify blade geometry and coefficients, as well as some other model related info. When it runs, the velocity at the inflow face and rotor speed is used to calculate blade forces using what essentially amounts to BEM theory. It looks like from the help files that you can create a virtual disk angle report, but it's not immediately clear if that is spanwise angle of attack or not. I encourage you to do some reading and maybe play around with it. |
March 10, 2015, 05:40 |
lin lin
Rep Power: 11 |
Thank you. now I am trying the virtual disk method. And I found a paper "determination of angle of attack for rotating blades" from Wen Zhong Shen to find the AOA
March 17, 2015, 04:34 |
David
Rep Power: 14 |
wo shi lai guan shui de xiao shi mei
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 17:18 |
Effective angle of attack rotating blade | ebah6 | FLUENT | 0 | March 7, 2013 15:04 |
Calculating lift force of a wind turbine blade problem | LittleBart | CFX | 4 | June 29, 2011 02:33 |
Wind turbine blade meshing | caohan | FLUENT | 12 | April 22, 2010 10:49 |
wind turbine blade pressure picture | amit | Main CFD Forum | 0 | December 15, 2005 08:41 |
