March 6, 2015, 17:19 |
Shear conditions on walls in a channel
Rep Power: 14 |
I want to simulate an object moving in a channel where the walls would be close to the object. I know I can do that with a moving mesh, but since I want to save computation time and cells, I thought I could just have a short section of the channel, my fixed object inside it, and have the air flowing through. The thing is, here the walls are pretty close to the object and I end up with this issue: - in the real application where it is the object that is moving in the channel, the air is static and does not moved with respect to the walls. In my new setup, the air is moving with respect to those walls. - I believe that simply putting a "slip" condition on the walls does not have the same effect. Is using the "tangential velocity specification" and adding a vector corresponding to the velocity of the air the thing to do ? Unfortunately, I cannot run the moving mesh to compare and make sure I have the right setup in my "fixed frame" simulation... thanks for your help! |
March 6, 2015, 18:09 |
Matt
Rep Power: 18 |
Sounds like you are on the right track. No slip is for a 'frictionless' surface, you have friction. Your surface is moving, aka a moving wall. I have never used it, but from the help documentation it sounds like tengential velocity specification is what you want.
March 7, 2015, 23:58 |
Gajendra Gulgulia
Rep Power: 13 |
Hi
if increasing in computation time is what you are afraid of in your case, you can do an initial study of comparison by using tangential velocity-fixed frame and no slip velocity-moving reference frame (maybe a cylinder in a pipe) and see how the results compare. This will give you a fair idea of the trade-off you will be in for. |
March 16, 2015, 17:35 |
Rep Power: 14 |
thank you guys,
I am comparing the "fixed mesh" simulation using the tangential velocity boundary and the moving-mesh that I was able to cut short enough so that I can make it run with an acceptable mesh, will see what the results give! |
boundary conditions in FLUENT VOF for open channel flow | newcomer | Fluent Multiphase | 33 | May 28, 2024 14:41 |
Shear Stress Specification at Walls | daniel | FLUENT | 2 | April 18, 2013 03:38 |
Boundary conditions problem for flow blockage analysis in a channel | mqasimali | FLUENT | 3 | March 6, 2013 09:26 |
wallHeatFlux for heated walls in laminar channel flow | svens | OpenFOAM Post-Processing | 0 | June 20, 2009 21:33 |
UDF: Function to Acces Shear Stresses at Walls | daniel | FLUENT | 0 | March 13, 2000 20:31 |
