March 6, 2015, 08:21 |
Issue simulating rolling in head waves
Alistair Galbraith
Rep Power: 11 |
The aim of my project is to simulate a Tumblehome vessel travelling in headwaves and investigate the parametric rolling that occurs. Though it runs perfectly when it is not rolling as soon as rolling occurs, severe problems occur, particularly with the free surface.
I have been advised to use an overset mesh, however I am enquiring how best to follow in the tutorials in regard to my project and what other steps should I take to get to the stage of obtaining useful results. I am also wondering how do I create create the background and the overset geometries from scratch, do I do it the same way as in the resistance tutorial or do I do it in a different set up as there is two separate parts required? How to I include my ship in the overset geometry and not the background? How large should the overset mesh be surrounding my ship? Is there a maximum and minimum recommended size? The tutorial for the lifeboat stated that physics continua should be laminar, however the headwave tutorial stated it should be turbulent, therefore for my simulation which should I choose? For transformation, like what the tutorial suggested, to encourage the parametric rolling, would I rotate the ship a certain number of degrees around the x-axis? Should the boundary conditions be set up in a similar way to the lifeboat tutorial considering that I am looking at headwaves? Any help will be much appreciated. |
March 6, 2015, 10:58 |
Matt
Rep Power: 18 |
I would recommend talking to tech support if you have worked the tutorials but are having a tough time getting started with your model. They can usually bridge the gap between the two fairly easily.
I wish I could be of more help, but your are venturing into territory foreign to us aero-nerds. |
July 7, 2016, 06:30 |
#3 | |
Maharashtra
Rep Power: 10 |
hi did you get any help? Please forward me too. |
head seas, overset mesh, rolling |
how to calculate mass flow rate on patches and summation of that during the run? | immortality | OpenFOAM Post-Processing | 104 | February 16, 2021 09:46 |
Tutorial - Heave and Pitch Simulation of Ship hull moving through head sea waves | Cam | FLUENT | 6 | February 13, 2019 19:12 |
Simulating Ship Motions caused by waves in STAR-CCM | Aitken Mitchell | STAR-CCM+ | 3 | August 8, 2014 06:07 |
Set up of head waves case | nollnoll | Fidelity CFD | 2 | April 10, 2014 04:13 |
How to apply pressure 6.2psi on the upper spinnig head | msormania | CFX | 0 | April 26, 2012 20:25 |
