Floating point exception error
Old   March 3, 2015, 11:51
Default Floating point exception error
Xiaosong Zhang
jsb12136 is on a distinguished road
Hi,all.
I am trying use Star ccm+ to simulate the rotation of a vertical axis water turbine with 3 blades. The model is regarded as a disk rotating in a stationary region. The results went diverge and "Floating point exception error". I use scalar scene to observe the flow velocity through the disk (which is the region of swept area ). I found that the velocity went sky high at the interface between the disk region and the stationary region. I have tried to change the mesh size, time step, interface boundary conditions, but nothing helps.
Please help me to break this ice so I can continue my study.
jsb12136 is offline   Reply With Quote
Old   March 3, 2015, 14:24
Gajendra Gulgulia
ggulgulia is on a distinguished road
can you extenuate on the rotation motion method? Is it MRF, RBM or overset method. In case it's Rigid Body Motion (RBM) or Moving Reference Frame (MRF) you need to make sure that you've created the z-axis at the center of the disc
ggulgulia is offline   Reply With Quote
Old   March 3, 2015, 15:41
Xiaosong Zhang
No, its not rigid body motion. I have created z-axis and its a disk fluid region I made it rotating.
floating point error, interface, mesh, star ccm+ v9
error compiling modified applications yvyan OpenFOAM Programming & Development 21 March 1, 2016 05:53
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
Floating point error and divergence detected aannjj FLUENT 0 July 2, 2013 04:44
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
