March 2, 2015, 14:00 |
Mass Flow Inlet and Instability
Matt
Rep Power: 18 |
Occasionally, when running a case, I encounter an issue where the mass flow inlet I have defined (operating with a negative flow rate) will cause considerable instability in my model. Specifically, the density near the boundary condition will crash and approach zero. I have even heard of it going negative for someone else.
Has anyone ever experienced this and do you know what I can do to avoid it? |
March 3, 2015, 14:19 |
Gajendra Gulgulia
Rep Power: 13 |
negative flow rate implies ( assuming you are using CCM+ mass flow report) that the mass flow rate direction is opposite to the normal of the boundary, hence mass flow rate at inlet boundaries is usually negative.
In this case if the residuals are jumping too high, you should try checking the CFL number |
March 3, 2015, 14:53 |
Matt
Rep Power: 18 |
Negative mass flow rate was meant to imply a 'sucking' boundary condition. It is essentially serving the function of a compressor setting mass flow rate through an inlet design in a mixed internal/external aero analysis.
Its not an issue of residuals jumping too high. They do not behave well in general, but the cause is rooted in some kind of conflict between the boundary condition, turbulence model and prism layer mesh. I have been working with CD-Adapco support trying to resolve it, but so far we are mostly coming up empty. The current consensus is that a better initilization may help stabilize the solution. I originally started with quiesent flow which is where the issue first appeared. I then tried grid sequencing (expert initilization) but that had the same issue, albeit delayed. The results of the grid sequencing were pretty much garbage though. If you have ever used it with any regularity, you can sympathize I am sure. Currently trying to initialize regions independently with somewhat appropriate velocity and so far so good. If either the support people or myself come up with anything useful I will be sure to add it here. |
March 3, 2015, 14:54 |
Matt
Rep Power: 18 |
I should also mention that we tried CFL ramps with no luck as well.
low density, mass flow inlet |
Inlet Buzz?? | Mohammad Kermani | Main CFD Forum | 16 | February 12, 2024 20:07 |
Flovent instability | floventuser_89 | Main CFD Forum | 0 | May 17, 2014 08:22 |
Instability introduced by using mutRoughWallFunctions? | AlexC | OpenFOAM Running, Solving & CFD | 1 | March 18, 2014 15:14 |
How to reduce instability caused by inlet perturb? | leaf | Main CFD Forum | 1 | June 2, 2006 12:21 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 06:44 |
