How to create circular section plane in postprocessing
Old   February 23, 2015, 00:18
Default How to create circular section plane in postprocessing
Sangwoo Kim
swtbkim is on a distinguished road
Hi all.
How can I create circular plane?
I made a cylindrical region.
Diameter of the domain is about 4 m, and I want to make a circular plane with diameter of only 0.5 m for calculating mass flow rate or axial velocity.
I searched manual and this forum, but I couldn't find.
Should I use constrained plane? I could only draw the boundary in hand roughly, not specify the diameter.
Thank you in advance.
Best regards
swtbkim is offline   Reply With Quote
Old   February 23, 2015, 12:33
Lane Carasik
lcarasik is on a distinguished road
If you have access to the CD-Adapco's Steve portal, look for the article titled "How to create a plane section with a predefined shape." It looks like what you are hoping to do.
lcarasik is offline   Reply With Quote
Old   February 23, 2015, 21:11
Sangwoo Kim
Thank you. and I can access Steve portal.
I searched the article in 'knowledge base' but I couldn't find the article.
I think it's because I use Korea server.
I think I should define some geometry like a circle in advance, right? ..by guessing from the subject of the article.
can you explain it briefly?
Thank you.
Best regards
Old   February 24, 2015, 20:45
me3840 is on a distinguished road
No, use the derived part> section>cylindrical for this.
me3840 is offline   Reply With Quote
Old   March 3, 2015, 15:13
Matt
fluid23 is on a distinguished road
If you are after a annular section of constant radius (i.e. a hollow tube) then do what me3840 suggests.
I am not 100% clear on what your domain looks like, you say your domain is 4m in diameter and you want a section that is 0.5m in diameter. Is this floating in free space? Is there structure around it, like maybe a duct that is .5m?
If you are trying to get a circular cross-section within a duct that is surrounded by a larger air volume, do this...
1. Make sure your geometry is split so that the duct is it's own surface. Remesh (surface and volume) if necessary.
2. Create a derived part > section > plane.
3. Select ONLY the duct wall REGION BOUNDARY for your input parts.
4. Set the appropriate origin and normal.
5. Select any display parameters you want and click create.
If you are after something else, please clarify what you are trying to do.
fluid23 is offline   Reply With Quote
circular cross section in CFD post processing, Fluent Sahar FaPerhu FLUENT 2 March 15, 2013 15:37
how to make circular cylinder plane?? teguhtf FLUENT 0 May 27, 2012 05:34
Circular bounded plane Hento FLUENT 4 November 18, 2011 22:52
problem with meshing in gambit in circular section mohammadkm ANSYS Meshing & Geometry 1 August 24, 2011 02:15
plane section passing through an object sabry Siemens 6 July 6, 2008 12:31
