January 29, 2015, 00:24 |
Reverse flow and results does not converge
IreneLing
Rep Power: 12 |
Hi all, I hope someone can help me. I am facing a problem now.. I am simulating water and oil flow in a valve like element, and keep facing the problem of reverse flow at the outlet. isit normal to have reverse flow?
p/s I had extent the outlet to be longer then the 7-8x longer then the inlet. but still it shows reverse flow. Please help. |
February 4, 2015, 15:28 |
Rep Power: 11 |
What kind of outlet are you using?
Maybe you have to check your dimensions ( x-y-z- coordinates) and the values( - or + for the directions) |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
CAN'T CONVERGE WITH REVERSE FLOW AT OUTLET! | XIAOYI LI | FLUENT | 11 | September 14, 2012 16:43 |
target flow rate: varying results | Ryan | FLUENT | 3 | January 9, 2008 13:54 |
reverse flow | someshwar rao | FLUENT | 3 | March 9, 2007 03:35 |
