January 21, 2015, 11:47 |
Best way to study transient response?
Sicher Nygren
Rep Power: 11 |
Hi all. I have a counter flow heat exchanger set up and it works perfectly and gives me good results when I do it in steady state. I have an inlet mass flow rate of 0.028 kg/s for both the hot water which is at 80C and the cold water which is at 15C. When I tried to change it to transient response the results are screwed up.
What I'm trying to do is have both inlets at the same mass flow of 0.028 kg/s and be at 15C and then at some point change the inlet of the hot side to 80C and see how the heat exchanger reacts. If you guys have any idea of how I should set this up please share I would appreciate it very much! |
February 9, 2015, 01:01 |
Rep Power: 24 |
What do you mean by screwed up?
I don't think instantaneously changing the inlet temperature is very realistic for transient. |
Time step independence study for transient CFD simulation | Anna Tian | Main CFD Forum | 50 | October 26, 2021 12:02 |
Transient simulations: how to tell its converged (I've read the FAQ & user guides!) | JuPa | CFX | 12 | March 27, 2020 17:24 |
1-way time step problem in doing FSI between Fluent and Transient Structural | sihaqqi | ANSYS | 0 | November 21, 2013 02:45 |
Input File for transient cavitating flow | Badi | CFX | 13 | July 1, 2013 09:28 |
Transient flow in fluent | linyx | FLUENT | 15 | April 24, 2013 09:54 |
