Momentum Source
Old   January 6, 2015, 22:55
Default Momentum Source
Lucia Antonius
Lucia is on a distinguished road
Hi, I'm new to CFD and encountering some problem when I want to add a momentum source term.
The source term I want to add is +[angular vel ^2]x[position vector] to the left hand side of NS Equation (and it must be a positive term), which happens due to pressure correction in a transient simulation with increasing angular velocity. My questions:
1. Which momentum source options should I use? I've tried simple dimensional analysis [normal and derivatives] and they have different units with my source
2. If I use this feature, does that mean I'm adding the term to the LHS of NS Equation?
3. Since the value varies with angular velocity and the position vector (the position of the fluid at specific time), which field function (and coordinate) should I use?
Thanks,
Lucia is offline   Reply With Quote
Old   January 8, 2015, 00:39
Lucia Antonius
Anyone? Any advice will be very welcomed
Old   January 17, 2015, 23:42
shuai_manlou's Avatar
CAO Liushuai
shuai_manlou is on a distinguished road
I am a fresh man in Star CCM+, and i don't know how to add momentum source in this solver. But in Fluent, momentum source can be added by User Defined Functions into cells.
1. the momentum source will not be necessarily in LHS, and can be included in external forces (vector f) in RHS in N-S equations
2. in Fluent, the postion vector can be expressed by x[ND_ND], the angular velocity can be defined by yourself. Thus, you can just define the expression of momentum sources and hooked in the Fluent solver
This is what i know, hope it's helpful
shuai_manlou is offline   Reply With Quote
momentum source, star ccm+
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
[swak4Foam] Error bulding swak4Foam sfigato OpenFOAM Community Contributions 18 August 22, 2013 13:41
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 14:14
Mass source, Momentum source theory. diffo FLUENT 4 August 21, 2009 11:26
Problem with Mass source, Momentum source theory diffo Fluent UDF and Scheme Programming 0 August 20, 2009 07:10
