Unrealistic Temperature Gradients after refining mesh in some parts |
December 16, 2014, 09:28 |
Rep Power: 12 |
I want to keep it short and describe my problem. I generated a 2D Mesh for ribbed channel where I want to analyse conjugate Heat Transfer and validate experimental Nusselt data. Some key facts from my analysis: K-omega SST turbulence model, Contact-IF between Solid(Rib) and Fluid, AllY+-Treatment, WallY+ 0-13 ,Air enters the channel with an Temperatur of 293,15K, I set a constant heat flux of 200 W/m² for the channel bottom and rib bottom . The channel consists of 12 ribs. The flow can be assumed as periodic. Therefore I evaluated just the Nu-Distribution between rib 9 and 10. I've generated a grid which had a really good accurancy but I couldn't get satisfactory results for the validation. Based on that I decided to refine the mesh from rib 9 to rib 10 and the walls were Heat is transfered. After refining I got a Wall Y+ values of <1 ( just for the near wall area from rib 9 to 10, rest of the channel remained between 0-13) I expected to get better results (means more equal to the experimental data as before) in the refined area. However I got unrealistic temperature gradients in the refined area of the solid and bad accurancy. Can someone describe why the solution is that bad ? I put some pictures in the attachment for better illustration. I hope this helps.Thank you. |
[snappyHexMesh] problems generating clean mesh | Christian_tt | OpenFOAM Meshing & Mesh Conversion | 2 | June 20, 2019 06:39 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 22:11 |
icem hexa mesh parts pb | jaber | Main CFD Forum | 2 | July 7, 2009 16:30 |
icem hexa mesh parts pb | jaber | FLUENT | 0 | June 12, 2009 19:06 |
