How to know when velocity profile is fully developed? |
December 9, 2014, 21:44 |
Rep Power: 11 |
Right now I created a scalar scene that shows the velocity profile throughout a pipe with water flowing, and by 'looking', I can tell that it is nearly fully developed at around 3 seconds time. Can anyone suggest me a method that will allow me to have a more accurate time at which the velocity profile is fully developed? Thankyou |
December 10, 2014, 11:07 |
Pauli
Rep Power: 17 |
Run a steady state solution to convergence?
December 16, 2014, 07:06 |
Rep Power: 11 |
A visual check of a scalar scene developing is a pretty reasonable method for judging your solution in this case, however there's no history in a scalar scene. Try creating a couple of reports and plots for velocity related functions through your region (volume average velocity, maximum velocity, etc). Watch these plots as the solver is running and once the lines have levelled out that's a pretty good sign the velocity profile is stable.
January 15, 2015, 17:20 |
could you please elaborate more what are you doing? Perhaps I can help you a bit in this issue as I am working almost everyday on the flow development in pipes.
For a fully developed flow profile, the easiest approach is to take a periodic pipe boundary pair for inlet and outlet using the interface approach in starccm+. There you can either set the pressure drop across your pipe or the mass flow. Once you set the periodic case run the steady-state until convergence. On how to set exactly a periodic pipe you can check the documentation or contact support. Vivek |
fully developed velocity profile in 3D | S.S. | Main CFD Forum | 14 | January 11, 2017 14:06 |
time dependent BC with fully developed velocity profile | susheil | FLUENT | 6 | December 20, 2012 06:41 |
[Very urgent] How to write a C Source File For 3D fully developed | evolutionf33 | Fluent UDF and Scheme Programming | 0 | February 25, 2012 06:16 |
fully developed velocity profile | KS | FLUENT | 1 | November 12, 2008 09:36 |
inlet velocity profile for fully developed turbule | pankaj saha | Main CFD Forum | 4 | August 24, 2007 17:53 |
