Two-phase critical flow and shock modelling of nozzle
Old   December 4, 2014, 10:12
Default Two-phase critical flow and shock modelling of nozzle
Jógvan
Jeggi is on a distinguished road
Hi.
I am trying to use the experiments from an article in order to validate two-phase critical flow and shocks for water-air in STAR-CCM+. (Sadly, the article is behind a payment wall).
The geometry and boundary conditions can be seen in the image below:
The air inlet has a pressure of 6 bar and the outlet has pressure of 2.44 bar. The mass flow rate of water is fixed at 498 kg/h.
I am using the Eulerian multiphase segregated flow solver with both water and air set to be compressible. I have been able to obtain reasonable results for the critical mass flow rate, but it has not be the case for the pressure profile along the nozzle as STAR-CCM+ does seem to over-predict the shock.
As of now, I have been using the S-gamma model in order to describe the interaction length scale for the two-phases by the Sauter Mean Diameter as recommended in the user guide (for droplets/bobbles). My issue is though that I don’t know if this model is applicable for my case?
It is also possible to set the interaction length scale to a constant, but I am hoping to avoid this as it will make it troublesome to transfer the validation case to a real case. Or is there a way to calculate the interaction length scale base on physical properties ?
Any help would be greatly appreciated.
- Jeggi
Jeggi is offline   Reply With Quote
critical mass flow rate, s-gamma, shock, two-phase
Different flow patterns in CFX and Fluent avi@lpsc FLUENT 4 April 8, 2012 07:12
Con-Div Nozzle Shock structure problem padmanathan FLUENT 2 November 16, 2010 04:37
Nozzle flow simulation in inviscid and viscous Cath FLUENT 0 January 28, 2007 03:16
Nozzle Flow with shock jim clancy FLUENT 1 December 18, 2001 05:19
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
