Modeling Liquid RTD in single phase flow Using a Pulse Tracer (dye)
Old   November 21, 2014, 04:17
Unhappy Modeling Liquid RTD in single phase flow Using a Pulse Tracer (dye)
Emmanuel Kimuli
R.B.Riddick is on a distinguished road
Hi CFD Masters,
I am trying to model liquid Residence Time Distribution (RTD) in a fairly simple geometry (Baffled pipe). At the moment am trying to do this for a steady-state simulation and later on will do it for unsteady inlet boundary conditions. I have tried using the Lagrangian multiphase model (with a track file; recording residence time) but the results I obtained were unreliable when compared to the theoretical and experimental. I have embarked on solving this using a tracer dye. However I do not know how to do this in STAR-CCM+ and the help files were not very helpful. Some of the questions I have include;
1.How do I go about doing this in STAR CCM+; a step by step description would be helpful.
2.Do I have to set up a separate inlet for the tracer(dye)?
3. Does the tracer have to have the same properties as my Liquid (water)?
4. Will I need to specify a velocity for the Tracer
5. I would like for the dye to be injected as a pulse(within a very short period of time), how can I achieve this.
6. And finally how will I be able to obtain an RTD curve from post processing or from exporting simulation results?
Because the baffled tube is spatially periodic, I have a fully developed periodic boundary interface set up at the inlet and outlet. I do not if this will have any effect on the usual procedure followed to model RTD in STAR-CCM+.
Thank you for your help in advance.
R.B. Riddick
R.B.Riddick is offline   Reply With Quote
two phase flow, compressibility of liquid phase Ardalan Main CFD Forum 0 February 7, 2014 04:56
Two-phase/ Single phase mix flow Reza Main CFD Forum 1 August 6, 2003 07:36
CFD Modeling of Two-phase Flow in Small Dia.Tubes Eric Poindexter Main CFD Forum 2 September 22, 2000 10:21
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 16:00
