November 20, 2014, 11:18 |
Eulerian model + Drift-Flux model
Nicolas
Rep Power: 17 |
Actually, I am working in the CFD modeling of multiphase flow in vertical pipes using the eulerian multiphase model. Using the Schiller-Naumann method to calculate the drag force coefficient the simulations don’t have any problem. However, this simulation configuration presents not accurate results. For this reason, I am studying the performance of the eulerian multiphase model, where the drag force coefficient is calculated with a drift flux model. For this reason, I am using the linearized drag force method that follows the following equation:
F_ij^D=A_ij^D (v_j-v_i ) Where the linearized drag force coefficient is calculated with the following equation: A_ij^D=3/4 C_ij^D (α_j ρ_i)/d_j |u_j-u_i | Additionally, the drag coefficient equation is: C_ij^D=4/3 (ρ_i-ρ_j)/ρ_i gd_j 1/(u_D^2 ) Where the Ud will be the drift velocity equation of a Drift-Flux model. I have tried 19 different models but I get convergence problems. I am using a field function to write the linearized drag force coefficient. Anyone have model this problem who can tell me which drift-flux model can I use? Or how can I modify the solvers parameters to avoid this convergence problems? Thanks, |
drift flux model, eulerian model, multiphase flow |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
Eulerian model with mixture ke turbulence model | Diegoesteban | FLUENT | 0 | September 3, 2014 00:22 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 18:44 |
