Particulate Flow not converging
Old   October 4, 2014, 11:44
Default Particulate Flow not converging
Yesaswi
yesaswi92 is on a distinguished road
I'm using Star CCM+ for simulating the filling of particles in a vertical pipe. The pipe is blocked at the bottom end, and I'm using injectors to add particles into the pipe from the top. The models I'm using are,
- Implicit Unsteady
- Lagrangian Phase
- Discrete Element Methods (DEM)
- Hertz-Mindilin Contact Model
After the particles get filled in the pipe, some of them start to penetrate out of the pipe wall and go outside the domain. The velocity magnitudes of the particles are also varying erratically.
Where did I go wrong? What could have possibly made the particles to go completely out of the domain? Is it the particle properties or something with the simulation models?
I did the same simulation with a shorter pipe and lesser number of particles. This never happened with that simulation. I'm guessing something is going wrong with the large number of particles.
Can someone please help me with this??
- Yesaswi
yesaswi92 is offline   Reply With Quote
Old   October 4, 2014, 18:52
me3840 is on a distinguished road
Use the coupled solver and a high CFL to make sure that your timesteps are converging well.
me3840 is offline   Reply With Quote
Old   October 7, 2014, 13:45
Yesaswi
Thank you.
I used smaller time steps and it worked.
Old   June 7, 2015, 03:29
Ayush Jain
Ayush Jain is on a distinguished road
Originally Posted by yesaswi92 View Post
- Implicit Unsteady
- Lagrangian Phase
- Yesaswi
Hi Yesaswi!!
How to decide the time step for lagrangian models, as when the unsteady lagrangian solver starts I am not able to know whether the solution is converging within the substeps.
What is active parcels??
How it calculates the progress percentage??
how maximum substeps are decided?
Ayush Jain is offline   Reply With Quote
dem, lagrangian phase, solution diverged, star ccm
Flow through circular pipe not converging Tanjina FLUENT 8 June 12, 2013 16:47
Not converging flow around cylinder with Re=1000000. Help please! Wotild ANSYS 5 December 7, 2010 22:07
Converging problem of buoyancy flow Cadrian FLUENT 4 January 19, 2007 18:09
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
stability of converging flow Bo Busk Jensen Main CFD Forum 2 October 17, 2001 03:38
