October 2, 2014, 20:40 |
Field Function Problem
Mohammed Gowhar
Rep Power: 12 |
Hi all
I am on the moving frame of reference. I measure the Velocity on Z-direction and find the new height reached by my body. Initial Height h0 = 41 meter h=$h+($Vz*$TimeStep) At every time step i gain new height and i want to get tat new height so tat i can implement to use it on Standard Atmosphere Density Distribution formula. Thanks in Advance Cheers Gowhar |
October 3, 2014, 09:08 |
Chaotic Water
Rep Power: 18 |
If i understand your question right - Field Sum Monitor of "$Vz*$TimeStep" with corresponding Report would help: you will get your additive value of "$h+($Vz*$TimeStep)".
October 3, 2014, 13:19 |
Mohammed Gowhar
Rep Power: 12 |
"Field Sum Monitor" sum the values of "$Vz*$TimeStep" of all the cells of selected Region. I want to create a report and monitor the $hReport=$hReport+($Vz*$TimeStep) in the simulation and use the "$hReport" as input for Atmosphere.
I have attached the image of the Formula which i required to create and monitor In this h(n+1) is current time step. h(n) is value at previous time step. I hope you understand |
altitude, field function, height function, starccm+ |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 11:05 |
[blockMesh] Errors during blockMesh meshing | Madeleine P. Vincent | OpenFOAM Meshing & Mesh Conversion | 51 | May 30, 2016 11:51 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 01:35 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
