Low Reynolds Number
Old   September 24, 2014, 22:22
Default Low Reynolds Number
Isaac
isaac1326 is on a distinguished road
Im doing a CFD analysis on a NACA 0012 wing, with a AR of 5.0 at a Re number of 80000. I am validating it with an experimental data. Im still unsure which model I have to be using , whether to go with laminar or use turbulent BL. When I have used , laminar model, the lift coefficients matched, but the drag coefficients are far way off.
Experimental @ 5 degrees
Cl - 0.4, cd -0.12.
My analysis
Cl -0.38, cd -0.06.
Any help in helping me solve this, is deeply appreciated
isaac1326 is offline   Reply With Quote
Old   September 28, 2014, 21:28
Gabriel Boucher
Alfalfa is on a distinguished road
I guess you could use a low-Reynolds Turbulence model such as k-omega sst. Those are usually good for external aero purpose. That being said, in my experience I've found that it's always hard to match the drag values.
Alfalfa is offline   Reply With Quote
Old   September 29, 2014, 03:30
Isaac
Iv tried that too, Iv played with the turbulence intensity and viscosity ratio too, still no avail , is there a limiting factor for Tu?
Old   September 29, 2014, 18:50
me3840 is on a distinguished road
What does your grid look like? That's more than likely the problem.
me3840 is offline   Reply With Quote
Old   September 29, 2014, 19:04
Lane Carasik
lcarasik is on a distinguished road
Could the Turbulence Suppression model help in this problem?
lcarasik is offline   Reply With Quote
Old   October 1, 2014, 15:21
Isaac
I have 300 grid points on the airfoil, and y+ = 0.8,
Regarding the grid, my only question, shd i keep dropping the y+ value, to see if my results would get any better?
Old   October 1, 2014, 15:22
Isaac
Yes, i have used Turbulence Suppression Model, but the answers still did not change. I am running this simulation in Star CCM+, and i used, SA model, and tried playing with turbulence viscosity ratio, the Cd value increased to 0.89, but I didnt see any major changes,
Old   October 1, 2014, 17:45
You're doing LES for this?
Old   October 2, 2014, 11:29
Isaac
I am doing RANS for this
Old   October 2, 2014, 13:10
I thought the turbulent suppression model was for LES.
Anyway, can you show me the grid?
Old   October 3, 2014, 01:27
Isaac
http://www.4shared.com/folder/prFsZuQ1/_online.html
Old   October 4, 2014, 18:48
Your near-wall layers seem to be really coarse. What is your wall y+?
Old   October 4, 2014, 23:10
Isaac
I have kept it as 0.5
Old   June 9, 2018, 06:12
Default same problem different issues
  #14
shashankshankar is on a distinguished road
hello Isaac
we're you able to resolve?
in my case drag coefficient is captured with minimal error of 1-3% whereas lift coefficient is way off. any help or suggestions please
shashankshankar is offline   Reply With Quote
fluent, naca 0012, star ccm+, wing simulation
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[blockMesh] --> foam fatal error: lillo763 OpenFOAM Meshing & Mesh Conversion 0 March 5, 2014 11:27
decomposePar pointfield flying OpenFOAM Running, Solving & CFD 28 December 30, 2013 16:05
Low Reynolds number question wildfire230 OpenFOAM Running, Solving & CFD 7 December 13, 2013 05:34
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 11:37
