Question Regarding to Export and Import The Velocity Profile |
September 18, 2014, 21:00 |
Junhong Li
Rep Power: 12 |
Dear all,
I'm a beginner to the Star CCM+, I have a question regarding to export and import the velocity profile. I hope any of you could provide some advice. Thanks in advance. Here is a detail description of my problem: I want to simulate the flow passing an obstruction using the DES method. First, I construct a rectangular flume model to generate a fully developed turbulence, and then wanna to use the outlet conditions of this first model as the inlet boundary conditions of my second model, which contains a bridge pier in the flume. But I couldn't figure out how to export the velocity profile from the first simulation result, and how to import the velocity profile into my second model properly. Any help is greatly appreciated. |
September 19, 2014, 06:05 |
allan thomson
Rep Power: 17 |
Hi
Go to tools -> tables -> create new internal table, choose part (probably outlet) and your variables, extract the data. Then export the table to a file. Open your other model, tools -> table -> read from a file. For your boundary condition choose table as your method and in value choose your selected variable. azt |
September 19, 2014, 09:34 |
Junhong Li
Rep Power: 12 |
Hi allan,
Thanks for your answer. That's exactly what I'm looking for. Also, beside selecting the table method to set the boundary conditions in my inlet surface node under the Region, should I also add the boundary condition in the 'intial conditions' node under the continua-physics? Thanks again. |
September 19, 2014, 09:57 |
allan thomson
Rep Power: 17 |
Hi
Initial conditions are the are for the complete domain, not just boundary conditions. To do this you would need a table for the whole flow field. So the answer is no. azt |
September 19, 2014, 10:01 |
Junhong Li
Rep Power: 12 |
Thank you so much. Allan.
export, import, star ccm, velocity profile |
Export and import vector data | mcribas | FLUENT | 1 | July 30, 2014 13:42 |
Export & Import Velocity profile as Inlet | eRzBeNgEl | STAR-CCM+ | 6 | March 26, 2012 06:16 |
STAR-CCM+ import and export not working | rks171 | STAR-CCM+ | 1 | December 29, 2011 15:20 |
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
Importing I-DEAS unv file | hbetb | FLUENT | 1 | August 10, 2001 14:22 |
