grid independence test issue
Old   September 8, 2014, 11:21
Default grid independence test issue
Djordje
djordje8 is on a distinguished road
My domain is 600 m tall and I have 3 grids (4.03 mill, 4.75 mill, 5.74 mill cells). If I create a presentation grid with 21 points in the vertical direction, then the highest point on the 4.75 mill cells grid is at 586.96 m, while the highest point on the 4.03 mill cells grid is at 600 m.
So, independently of what I am using to measure the distance from the bottom (Position(z), WallDinstance, or Centroid), I always get that the heights are dependent on the grid. Therefore, how can I do the grid independence test if I collect velocity data that are not at the same heights? In the previous example, I would compare velocity at 586.96 m against velocity at 600 m!
Please could you help me with this? Does anybody else have a similar problem?
Thank you,
Djordje
djordje8 is offline   Reply With Quote
grid independence, line probes, presentation grid, wall dinstance
grid independency test gafoorcp AVL FIRE 2 September 5, 2014 08:07
Grid Independence of Boundary layer Luigi_ Main CFD Forum 0 December 14, 2011 14:42
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Problems in compiling paraview in Suse 10.3 platform chiven OpenFOAM Installation 3 December 1, 2009 08:21
On grid independence David Chabot FLUENT 0 May 31, 2005 12:22
