DFBI Superposed rotation inside overset mesh.
Old   August 28, 2014, 07:56
Default DFBI Superposed rotation inside overset mesh.
CFDguy
rockydongre is on a distinguished road
Hey guyz,
I want to find the trajectory of a propeller driven aircraft. So i am thinking of using overset meshing and by giving DFBI to the whole aircraft body and giving DFBI superposed rotation to the propeller. so is it possible?
thanks in advance.
rockydongre is offline   Reply With Quote
Old   August 29, 2014, 05:34
Ping
ping is on a distinguished road
yes this is possible
ping is offline   Reply With Quote
Old   August 29, 2014, 06:20
CFDguy
so we can have sliding mesh inside overset mesh? i thought since overset mesh performs the hole cutting process, we cannot use sliding mesh inside an overset mesh.
Old   August 29, 2014, 07:08
Ping
if you need me to say yes again then yes it can be done and was shown at the global conference this year
and if you are using a recent version eg 9 you can can overlapping overset meshed regions which means the propellor could be in an overset region inside the other overset region rather than within a sliding rotation region
Old   August 29, 2014, 10:13
CFDguy
actually i am simulating an airship in which there are two propellers attached to its body through two suporting rods. now to provide thrust vectoring these two rods can be swiveled around and change the angle of thrust of the propeller. so to model this i was thinking of using overset mesh, but for the rotation motion of the rods and propellers, i need to use sliding mesh. also i am thinking of using dfbi motion to find out its trajectory.
i have posted a question on this with some fotos in this thread.
http://www.cfd-online.com/Forums/sta...rset-mesh.html
please take a look at this.
thanks in advance for ur help.
Old   August 30, 2014, 15:45
CFDguy
So when i did all this i could not align the propeller and rod with the motion of the airship. so what should i do to align the region of the rod rotation and propeller rotation with the airship?
Old   September 2, 2014, 10:37
Ping
you use two motions being a normal dfbi rotation and translation and a dfbi superimposed rotation and apply this second one to the propeller region and add the propeller surface to the dfbi body parts
Old   September 2, 2014, 14:36
CFDguy
as i mentioned earlier i am simulating a case in which the propeller is rotating as well as swiveling, i.e. providing thrust vectoring to the airship. in this using dfbi superimposed roation will not work. i tried using rotation for swiveling and then superposed rotation for rotation of propeller but inspite of keeping the coordinate system of the motion of the propeller aligned with the swiveling motion and also keeping the swiveling motion aligned with the airship, i could not able to align the propeller to the airship movement and everytime the propeller just moves away. what should i do?
Old   September 3, 2014, 09:03
Ping
i have not done this within dbfi and suggest you ask support about it
dfbi, overset mesh
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Superposed rotation with DFBI embedded rotation rockydongre Siemens 0 May 21, 2014 10:32
Overset: refine background mesh without resetting the mesh JohnAB STAR-CCM+ 6 May 19, 2014 14:48
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
