August 26, 2014, 23:21 |
Abnormal (?) Passive Scalar behaviour
Chaotic Water
Rep Power: 18 |
Simple case:
Rectangular axisymmetric 2D Porous Region 1.0x0.25m: Inlet (short edge; any kind of boundary condition - just for velocity about 1 m/s), Outlet (short edge; Pressure Outlet), Wall, Axis; Ideal Gas; Implicit Unsteady; Coupled Energy; Passive Scalar with "No Convection or Diffusion"; Region->Passive Scalar Source->Checked; Passive Scalar Source = 0.0; Initial: Temperature = 20 C, Passive Scalar = 20 Inlet: Temperature = 1800 C, Passive Scalar = 20 or 1800 Outlet: Temperature = 20 C, Passive Scalar = 20 Time Step = 0.025 s; The problem is that though Passive Scalar should be constant across the Region - its value increases just with the Temperature if Passive Scalar Source is switched on (though it is set to zero) and does not if Passive Scalar Source is switched off. I would be grateful for any suggestions or ideas - is it i am mistaken or it is a kind of program error. |
October 3, 2014, 09:05 |
Chaotic Water
Rep Power: 18 |
I am sorry to up the topic - but i still hope someone may clear the things out for me.
The problem remains the same: Passive Scalar with No Convection/Diffusion and with Passive Scalar Source checked but value set to 0 - is affected by the flow, while it should not as it its equation is just dϕ/dt = 0, where d - is partial derivative. This happens regardless of Time Step, Maximum Inner Iterations, CFL - and regardless of Residuals. |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 07:20 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 02:47 |
is internalField(U) equivalent to zeroGradient? | immortality | OpenFOAM Running, Solving & CFD | 7 | March 29, 2013 02:27 |
passive scalar for carbon monoxide | kraizy | STAR-CCM+ | 0 | October 12, 2009 21:13 |
