Setting Initial volume fraction for the DEM particles
Old   August 25, 2014, 05:18
Default Setting Initial volume fraction for the DEM particles
Anoop Jangra
anoopjangra is on a distinguished road
I am simulating an cylindrical shape mixer for lagrangian DEM particles. For this I need to fill the cylinder initially with particles. I want to know how to fill cylinder with DEM particles initially.
anoopjangra is offline   Reply With Quote
Old   August 25, 2014, 07:01
Ping
ping is on a distinguished road
you just inject the particles and let them fall into place
if you read the help you will learn that some injectors are better = quicker for filling than others
ping is offline   Reply With Quote
Old   August 25, 2014, 07:12
Anoop Jangra
Hi ping,
I am already using lattice injector hope which is the quickest, but still it takes a long time to fill it. And also it take longer to complete time-step as no of particles increases. I want to know if we can fill initially fill a portion of the cylinder with particles.
Old   August 25, 2014, 07:16
Ping
as i said read the help and you will learn about other injection methods eg a part injector
there are also lots of tips about how to speed up runs by adjusting particle properties while filling
steve will also help you with lots of tips
Old   March 26, 2024, 07:59
Samkelo
Samkelo is on a distinguished road
Originally Posted by anoopjangra View Post
Did you finally figure it out? Cause I am struggling with the same thing. Your guidance could be helpful. Thank you.
Samkelo is offline   Reply With Quote
dem, lagrangian particle
High Courant Number @ icoFoam Artex85 OpenFOAM Running, Solving & CFD 11 February 16, 2017 14:40
Unstabil Simulation with chtMultiRegionFoam mbay101 OpenFOAM Running, Solving & CFD 13 December 28, 2013 14:12
pimpleFoam: turbulence->correct(); is not executed when using residualControl hfs OpenFOAM Running, Solving & CFD 3 October 29, 2013 09:35
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 16:33
dynamic Mesh is faster than MRF???? sharonyue OpenFOAM Running, Solving & CFD 14 August 26, 2013 08:47
